Golan Remi
Hi All,
I have been using Asus AiMesh since it was first introduced. Current setup uses AC5300 as the router, 2 x AC68R and 1 x AC1900 as nodes. All connected via Ethernet cables and 1G Ethernet is set as priority. No issue in this setup and it is running the latest Firmware (always updated via the web GUI)
Recently I've converted a used T-Mobile CellSpot to an AC68U. Process was simple once I mtd-wrote the updated cfe.bin (tried both with manual update of the 3 MAC and WPS, as well as using https://cfeditor.feng.si/). I then proceeded to install FW_RT_AC68U_30043763626.trx followed by an update to the latest 3.0.0.4.386_45987. Every option works but AI-Mesh. To be clear, it works as a stand alone router or a repeater, but the 5300 refuses to recognize it as a mesh node. I thought my method to add it was flowed, so I removed a current working node and re-add it, no issue. I tried to add using WIFI, using cable, reset the node, reset the router (took a backup first
) clear the NVARM, nothing. What am I missing here?
RT-AC5300 - Current Version: 3.0.0.4.386_43576-g649d261 |
RT-AC1900P (70:4D) - Current Version: 3.0.0.4.386_45987-gb8fc0b6 |
RT-AC68R (E0:3F) - Current Version: 3.0.0.4.386_45987-gb8fc0b6 |
RT-AC68R (D8:50) - Current Version: 3.0.0.4.386_45987-gb8fc0b6 |
