Thanks, I got lost a bit - there are multiple threads on Wireguard Session Manager and some take me to Githut, older posts so not sure where to beging
If yo can kindly guide me please
I have AX11000 and Torgaurd VPN
Hi
@wizin
i would suggest that you choose a VPN provider who supports the WIreGuard protocol, like VPN Unlimited (KeepSoild) or Shellfire VPN. Both support the WireGuard protocol and provide easy to understand tutorials and VPN unlimited especially provides with just a few clicks on the Homepage a easy to use WireGuard configuration setup, just click and download the file, then upload it to the router or VPN application and you are good to go.
If you do not mind just use this code "
Z6LiT7gww4D8OiD3wKsq" to redeem a VPN subscription from VPN Unlimited with a 20% discount or
if you would like a German trustworthy VPN provider Shellfire then use this
LINK to redeem a discount and/ or a Shellfire Box which is the easiest way to cover your whole Network at home with VPN service and the WireGuard protocol already setup.
The Torguard is a term i do hear for the first time but i also do not have a AX11000 but a ASUS RT-AX88U VPN router.
best regards
