Solved [ASK] Assigning specific IP Range on different WIFI SSID (other than Guest Network)
adzie
Hello Expert,
as per subject, is it possible to assigning specific IP Range on different SSID (other than Guest Network).
For instance I have 2 SSID and IP range plan as follow.
WIFI2_4 : IP Range 192.168.1.10 - 192.168.1.50
WIFI5 : IP Range 192.168.1.51 - 192.168.1.60
any mods of script that I can use in order to achieve above settings?
thanks a lot in advance
Jeffrey Young
Yazfi may be of interest to you. Using that script, you can setup various SSID, including choosing your own subnet and the level of coms desired to other networks.
adzie
aha i thought Yazfi only works for guest SSID and I cannot change the SSID name, thanks mate will install that custom script ASAP
