sandiegoboy
Hi, I have the router AX86u with stock firmware. The backup CFG are encrypted. I have a fair bit of DHCP manual assignments I would like to be able to see. Does anybody have a recommendation of a tool to unencrypt (possible edit and re-encrypt) the CFG file
I found a couple of toos via google. One posted in github was giving an error (Also reported on github but dev decline to keep working on this). The other one kind of got some information but I couldnt see the DHCP data.
I wish there would be a way to transform into CSV or xml
