Mike Mckay
After a disappointing "support" session from Asus a friend suggested I tried to post my problem on here to see if anyone might have an answer
The problem with my router is that I can log in once after a complete reset, all menus work perfectly but the moment I log out, even without changing any settings other than Wifi and login passwords when I try to log back in the browser from any PC just sits there endlessly, times out or says it cant reach the host
I can however ping the router and the wireless and lan access and internet access all work fine
But if I ever need to change a setting I have to try and do it in one shot after a complete hard reset and hope I get it right first time
This has been the same since the original firmware version and has remained all the way up to the 4005 variant which is the latest one on the site which hadn't been an issue until now but I wanted to have a play with the Utorrent download and plugging in a hard drive which is almost impossible with it working like this
Has anyone had the same problem? And if so did you solve it?
Also, I have only used the standard Asus roms, would changing to a third party rom be likely to solve the issue or is it more likely to be a hardware problem?
All I got from asus was over an hours worth of upgrading to the exact same rom version three times and countless hard resets and reboots all of which had the exact same outcome of not being able to log back in after logging out after changing the passwords. The login screen "sometimes" comes up, but once the correct password and username is entered and the button to log in is clicked it just freezes then instead of before the login screen even appears
I am pretty close to just binning this as it just feels like a pile of junk and buying a totally different make and avoiding asus entirely from now on if nobody has a solution I can try
Cheers in advance for any help/advice offered
