Asus RT-AC86u AC2900 Router Same firmware but different numbers
Beowolve
Hey all, I tried my best to search this but didn’t have any luck finding answers. I don’t even know if the title is correct…
Does anyone know why they both have different ‘Firmware version’ numbers, first router 16_0 and the second 384_82072? Is it just like serial numbers but for firmware?
Nothing is wrong then them or has presented a problem from what I have been experiencing.
I did buy both routers second hand at seperate occasions. The first 16_0 18-24 months ago and the second 384_82072 last week. I asked the sellers but they forgot themselves.
Thank you
The 384 branch of firmware is obsolete and hasn't been updated for over two years. I suggest you manually update each router to the current 386 release which includes critical security fixes.
The 384.16_0 firmware is Merlin's third party firmware, not stock Asus firmware.
P.S. The RT-AC86U isn't an AC1900 device, it's AC2900.
Thank you so much Colin! I’m all over the place with this thread.
Should I manually update to 386 and then download latest Merlin’s firmware ?
I read that it’s a good firmware but I have to do more as to why it is and why to have it, etc.
The first question to ask yourself is "is there anything about Merlin's firmware that means I want to use it instead of Asus' firmware?".
If the answer is "no" then I suggest you use stock Asus firmware on both routers.
I don't know whether you can change your Merlin firmware back to Asus' using the app, I doubt it. So I suggest you download the current release from Asus to your PC, log into your router's GUI with a web browser and manually update it from there.
Do remember to complete the final step of the update procedure:
7. Please wait for a few minutes until the upload is completed.
Notice: It is recommended to restore to factory default settings by pressing the reset button on the bottom of the wireless router for 5 seconds after doing a firmware update.
Yes, I use my father's router rt-ac86u and mine and my sister's router with them are rt-ax86u and yes I would recommend more people use merlin asuswrt and it is better than asus' own firmware and better dns protection
Manually update both to stock Asuswrt 386_48260. Based on the questions you ask - this is the right firmware for you. You have to reset both routers to factory defaults after the update. This is a big jump in firmware versions - start fresh. Configure manually and not using any saved configuration files.
In all my 386 base firmware tests stock Asuswrt is more stable and consistent, including core function Wi-Fi and AiMesh.
