1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
ASUS RT-AC87U Firmware version 3.0.0.4.382.50702
Discussion in 'ASUSWRT - Official' started by JIPG, Jul 19, 2018.
  1. JIPG
    JIPG Occasional Visitor
    Sep 19, 2017
    30
    Spain
    Versión 3.0.0.4.382.50702 2018/07/18 44.62 MBytes
    - Improved system stability.
    - Fixed XSS vulnerability. Thanks to Yonghui Han of Fortinet's FortiGuard Labs.
    - Fixed CVE-2018-8877, CVE-2018-8878, CVE-2018-8879
    - Fixed plain text password vulnerability in lighthttpd
    - Modified Quick Internet Setup wizard process.
    - Main SSID and guest network can hide independently.
    - Suport multi-langue(UTF-8) network name
    - Modified the EULA for DDNS, AiProtection, Adaptive QoS, Traffic Analyzer, Web history, Feedback.
    - Added Privacy page in Advanced settings
    - Fixed IPv6 bugs
    - Modified USB 3.0 related strings.
    - Added more protection mechanism for OpenVPN account.
    - Limited Web&Apps filter number to 16
    * Windows XP and Windows 7 do not support UTF-8 format SSID. These two
    OS may see gibberish if using multi-language SSID.
    Please unzip the firmware file first then check the MD5 code.
    MD5: 73e49de69339502a8e98fa42da8da16c
    http://dlcdnet.asus.com/pub/ASUS/wi...8.2115068681.1532029699-1089302940.1532029699
    triple likes this.
  2. Kreeture
    Kreeture Occasional Visitor
    May 12, 2013
    17
    No AiMesh support, I guess it will never happen :'(
  3. Grisu
    Grisu Very Senior Member
    Aug 28, 2014
    1,437
    Aimesh starting with 384, this is 382!
  4. snbdora
    snbdora Regular Contributor
    Jul 23, 2014
    96
    USA
    Thanks. Aimesh on this router would be cool but not sure how much Asus is willing to work and push QTN for it afterall it was their first Wave 2 flagship router as claimed.
    Is the QSR1000 EOL/EOS if anyone know?
  5. xulian
    xulian Occasional Visitor
    Nov 27, 2016
    34
    How much did asus work on the others?
  6. dead_screem
    dead_screem Occasional Visitor
    Jun 17, 2013
    28
    Asus didn't even add Aimesh to AC3200... why would they bother with AC87?
  7. Kal-EL
    Kal-EL Very Senior Member
    Aug 15, 2013
    1,466
    Motor City, Michigan-USA
    A Asus rep here already said the 87 will get security updates but Aimesh will not be supported. If you want Aimesh your going to have to get a different model router.
  8. xulian
    Nov 27, 2016
    34
    I think he really wrote that it’s not planned at the moment
  9. Maastricht
    Maastricht Occasional Visitor
    Oct 1, 2015
    28
  10. fax
    fax Senior Member
    Feb 9, 2015
    310
    I am afraid, it is not to be expected any time soon.
  11. JIPG
    Sep 19, 2017
    30
    Spain
    Well, I bought it without Aimesh, and I can live now without Aimesh.
    But having this nice router updated in security and improved in other areas is what I am prying for. So please, ASUS, continue supporting this router ...
    And release the GPL code for the last FW. I would like to continue using Merlin versions ;).
  12. Kal-EL
    Aug 15, 2013
    1,466
    I doubt the 87 will ever get Aimesh. The 87's 5Ghz radio is Quantenna while Aimesh is designed around broadcom chip sets that alone is the deal breaker.
    Grisu likes this.
  13. Maastricht
    Oct 1, 2015
    28
    I agree and therefore hope ASUS will do so.
  14. VANT
    VANT Very Senior Member
    Feb 4, 2015
    725
    Poland
  15. xulian
    Nov 27, 2016
    34
    I cannot say the same. As other older and powerless models are getting this new functionality I’d like it also ported to 87s
  16. RMerlin
    RMerlin Super Moderator
    Apr 14, 2012
    28,882
    Canada
    The RT-AC87U architecture makes it unlikely to get AiMesh. The 5 GHz radio is entirely managed by a separate firmware from Quantenna.
  17. xulian
    Nov 27, 2016
    34
    Your knowledge is the best anyone can consider here. Thanks by the way for all your efforts with your firmwares, but I’m sure any technical problem has a solution.
  18. RMerlin
    Apr 14, 2012
    28,882
    Canada
    Not every solution is practical or economical to implement. If it ends up costing hundreds of thousand of dollars to have engineers work full time on this one specific model to rewrite everything required to make it work, it's not economically viable for Asus, especially for a model that is probably not generating any sizable sales in 2018, as better models are now available at a lower price.
  19. JIPG
    Sep 19, 2017
    30
    Spain
    I know it is frustrating that powerless and older routers can use this functionality, but as RMerlin says, our router has the specificity of having this damned Quantenna stuff (by the way, for me it works well, I am not complaining about the performance) and this makes more complicated for Asus to develop this part of the software.
    But again, it is a very good router (regardless some complains I have read around here), and I would like to have it updated altough it has no Aimesh.
    In fact, I will attach (if possible) to RMerlin FW that has no Aimesh. Many people here prefer it although in their model the Aimesh is operative in the stock FW.
  20. JIPG
    Sep 19, 2017
    30
    Spain
    I do not know in Canada, but in Spain RT AC87U is cheaper than the new (and better, I know) routers as RT AC86U, RT AC88U or RT AC5300, so it has still a good relationship price/performance. It is more expensive than RT AC68U, but it has better performances. In any way, it is still on sale ...
