Asus RT BE98 Pro dual 6GHZ bands question
airlung
Any one know how the dual 6Ghz band works on the BE98 Pro? Does it divide the 6GHZ band into 2, upper and lower or both the 6ghz bands get the full length? Thx
The BE98 is the one you want probably for your country where 5Ghz is split into two, not the 6 ghz. BE98 Pro is for the USA I think only. Plus it's probably more wise to wait a while for firmware to mature.
