Hi, I recently got a couple of My Book 4tb drives to hook up to my AX88U as network backup for my photos and documents. After adding about 2.2tb of files onto them, the transfer throws an error and stops. According to the web interface, the drives indeed still have ~1.5b free. My drives were initially formatted via my PC. This gave each of them a single 4tb partition of free space.
If I delete some files from the drives then I can once again add stuff...until I hit that 2.2tb threshold. Why am I unable to add more? According to ASUS support, the AX88U can handle drives up to 4tb: https://event.asus.com/2009/networks/disksupport/
After some experimentation, I discovered that an NTFS format via the router was different than an NTFS format via a PC. The NTFS format via the router uses MBR so it creates multiple partitions no larger than 2tb. Via the PC, I can choose GPT which gives me an unbroken 4tb partition. Is GPT causing issues with the router? Would the Merlin firmware help?
Thanks!
Thanks!
