AX88U Error
RedMaligator
After getting everything setup and running good, I'm getting this error. It was good and it auto switched channels to 161/80 shortly after I saw this error.
Sep 5 14:31:20 kernel: ^[[0;33;41m[ERROR vlan] bcmVlan_devHardStartXmit,536: Internal Error: Could not find Real Device eth6 on Transmission^[[0m
Also got this error:
Sep 7 03:21:10 kernel: ^[[0;33;41m[ERROR vlan] bcmVlan_devHardStartXmit,536: Internal Error: Could not find Real Device eth7 on Transmission^[[0m
Then looking at logs I saw this and that's not my SRC IP address and then my cloned MAC responded... Should it be responding?
Sep 7 00:16:16 kernel: ACCEPT IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:17:10:95:6d:11:08:00 SRC=150.181.101.11 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 PROTO=UDP SPT=67 DPT=68 LEN=308 MARK=0x8000000
Sep 7 01:50:57 kernel: ACCEPT IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:17:10:95:6d:11:08:00 SRC=150.181.101.11 DST=255.255.255.255 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 PROTO=UDP SPT=67 DPT=68 LEN=308 MARK=0x8000000
Sep 7 02:18:00 kernel: ACCEPT IN=eth0 OUT= MAC=80:aa:a4:a8:42:71:00:17:10:95:6d:11:08:00 SRC=150.181.101.11 DST=47.134.24.164 LEN=328 TOS=0x00 PREC=0x00 TTL=64 ID=0 PROTO=UDP SPT=67 DPT=68 LEN=308 MARK=0x8000000
Sep 7 02:48:36 kernel: ACCEPT IN=eth0 OUT= MAC=ff:ff:ff:ff:ff:ff:00:17:10:95:6d:11:08:00 SRC=150.181.100.23 DST=255.255.255.255 LEN=341 TOS=0x00 PREC=0x00 TTL=64 ID=0 PROTO=UDP SPT=67 DPT=68 LEN=321 MARK=0x8000000
Any ideas or is it an issue?
I have logs only posting accepted and I get a lot of these MAC=ff:ff:ff:ff:ff:ff:00:17:10:95:6d:11:08:00
That's normal DHCP broadcast traffic on your ISP's local network, ignore it. It's also not a particularly good idea to log accepted packets as it serves no purpose other than filling up your router's syslog.
What should I log declined?
Repost to make it clear, I don't know how did that... I was half asleep from writing...
Thank you!
