Best file format for USB HDD and HOW TO
webgurru
Hi All,
I want to know what is the best file format to get USB HDD worked with OPTWARE or ENTWARE? How can do this if I am on Windows 8?
I tried Ubuntu 12 under VMWare. Also tried EaseUS for Widnows 8 with no luck as Ubuntu 12 wont give an option of EXT3. EaseUS format to EXT3 but not readable by router.
Best regards,
Webgurru
Try to format the disk directly from router with this command in terminal:
mkfs.ext3 /dev/sda1
Hi All,
Best regards,
Webgurru
If you are still struggling in Windows there is a free tool that does a decent job
http://www.partitionwizard.com/ (make sure you click the free home version)
