Blocking specific apps on router or in scripts
Tbjeffee
Hello, I'm wondering if it's possible to block specific apps on the home network?
My niece seems to have made it a habit to grab grandma's, moms and dads debit/credit cards and spend money on Roblox. Her mother finally decided to block her use of Tik Tok (bad influence and the people she's talking to) and Roblox. I would like to ban the use of these while she is here but I have having trouble. I'd like to avoid setting up pi-hole (as I don't own a Raspberry Pie) when my RT-AC3100 is already doing most of the other things it does.
So far as of posting this I've only been successful in blocking the website in a browser but the apps still function as normal.
Things I've done.
Used YazFi to make a guest network using OpenDNS and blocking domains there. Even the websites were still working after blocking. It only allows 25 entries and the list for tiktok i've seen is massive.
Blocked these IP ranges for tiktok in Skynet; 103.136.220.0/24 and 103.136.221.0/24. Can't seem to block the ipv6 range.
wildcard blocked tiktok.com, roblox.com and rbxcdn.com in diversion. Since then the websites are blocked in the browser but the apps still function.
So is there anything I can do? I've found the regex list people use in pi-hole. Can that be used with a script for Asus-merlin?
I've also found Pfsense threads with lists to block everything from bytedance, is there somewhere I can import that?
Thanks for the assistance.
Router is an Asus RT-AC3100
Asus-Merlin version 384.18
install scripts:
Diversion
Skynet
YazFi
uiDivStats
Entware Packages for above scripts
I used to have unbound but I kept having DNS problems so I removed it and had to factory reset to resolve the issues after it was removed.
Be forewarned, blocking it not always possible. Most blocking schemes are based on manipulating DNS, but this assumes the app uses DNS! Nothing prevents the app from using explicit public IPs, or even a VPN! Just depends on how much effort the developers are willing to expend to get around your restrictions.
Still worth trying of course, but just realize that in the end, it's almost impossible to stop access to a domain/ip unless somehow you can find each and every one they use (and that's sometimes not an easy task) and block it at the firewall level, NOT DNS. Even then, they could change their domains/ips all the time to thwart even that.
Things I've done.
install scripts:
Diversion
Skynet
YazFi
uiDivStats
I recommend looking into the block feature of Skynet, option 2.
Select Menu Option:
[1]  --> Unban
[2]  --> Ban
[3]  --> Malware Blacklist
[4]  --> Whitelist
[5]  --> Import IP List
[6]  --> Deport IP List
[7]  --> Save
[8]  --> Restart Skynet
[9]  --> Temporarily Disable Skynet
[10] --> Update Skynet
[11] --> Settings
[12] --> Debug Options
[13] --> Stats
[14] --> Install Skynet
[15] --> Uninstall
[r]  --> Reload Menu
[e]  --> Exit Menu
[1-15]: 2
What Type Of Input Would You Like To Ban:
[1]  --> IP
[2]  --> Range
[3]  --> Domain
[4]  --> Country
[5]  --> ASN
use nslookup to find the ip for a domain.
# nslookup tiktock.com
Server:    127.0.0.1
Address 1: 127.0.0.1 localhost.localdomain
Address 1: 35.186.238.101 101.238.186.35.bc.googleusercontent.com
Use entware utility "whob" to find the ASN associated with the IP address.
# whob 35.186.238.101
IP: 35.186.238.101
Origin-AS: 15169
Prefix: 35.186.0.0/16
AS-Path: 2905 15169
AS-Org-Name: Google LLC
Net-Name: GOOGLE-CLOUD
Cache-Date: 1597564606
Latitude: 37.405992
Longitude: -122.078515
City: Mountain View
Region: California
Country: United States
Country-Code: US
Things I've done.
install scripts:
Diversion
Skynet
YazFi
uiDivStats
Are you using DNS Filters to force all devices to resolve through the router? I tried wildcard blocking tiktokv.com, tiktokcdn.com and everything Tiktok related broke.
An end optio
Thanks for the link, page never came up in my searches.
On the guest network using YazFi I enabled the force DNS option so I didn't get around the OpenDNS settings i made and my main PC has the program downloaded to refresh my IP for the DNS settings.
I added wildcard blocking for those two domains and tiktok is still working.
Thanks for the replies. I will the these settings suggested in the thread.
