Blocking the TOR network
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
anaknipedro
I'm trying to find a way to block the TOR network. Is it possible by importing the IP list from https://www.dan.me.uk/tornodes
I thought I had this working but I reinstalled Skynet after getting a load of 404 errors in Safari. After reinstalling and importing the list from dan.me.uk, TOR still gets through.
heysoundude
my understanding of TOR is that you have to permit yourself to be a routable node on the network - have you been, and you now wish to undo that?
(I use a browser - brave - that has Tor functionality built-in, and our Merlin-flashed routers have the capability to turn themselves into a Tor node IIRC...I've never tried. I'm much more interested in IPFS)
It's probably a good idea to log into the GUI of the router and check Advanced Settngs - VPN - TOR and select Disable if it is currently set to Enable and then hit apply.
Be prepared for some users to be upset if this breaks things for them.
HTH...but you really should use Tor for obfuscation/pseudonymity on the net. (or have they been hacked somehow recently? compromised by one of the letter agencies?)
EDIT- if you're using default login/pwd to the router and someone on your network has enabled Tor functionality in spite of your wishes, you should change things up and keep them private. If it's blocking users on your network from using Tor that you're looking to accomplish, I'm pretty sure the only way to do that is to deny them access to the network with credentials or by restricting device usage (if you're a parent concerned with your child's browsing, which is likely the case with CleanBrowsing DNS...)
anaknipedro
I'm familiar with the brave browser. That is what I'm using to test if TOR is working or not. I know the benefits of TOR and I understand there are many uses. My concern though it with protecting my children so I want to find a way to block it's use. Kids are very savvy these days and it ends up being a cat and mouse game. TOR functionality is disabled on the router settings.
heysoundude
TOR was built to bypass censorship, so if your kids are using it, they're using it as intended. You can only restrict access to their devices and your network.
I don't envy you the challenges/decisions you face.
heysoundude
Maybe it has become more possible in the last 3.5 years, sure. why not give it a try, and report back on your success/lack thereof?
