FireWire76
Hi.
I posted an issue about Network Services filter not working in:
http://forums.smallnetbuilder.com/showthread.php?t=12399
After resetting the router and configuration I finally found what is causing the issue. When parental control is enabled, the network services filter doesn´t work any more. If parental control is disabled, the network services filter immediately start working.
This isn´t an issue in the .270 firmware, but was introduced in .372 firmware and is still an issue in .374. I only tried the Merlin versions of these firmwares, so I don´t know if it´s the same in the Asus original firmware, but I would guess so.
@Merlin, any possibility to fix this issue or can you somehow report this to Asus, so they will be aware of this bug.
Best regards,
FireWire
Best regards,
FireWire
