Can´t see wifi from my AC86U
Orillion
I got my Asus RT-AC86U router last week and installed merlin firmware on it. it has run fine until now.
the problem is that i can´t see my 2,4 or 5 ghz wifi. it worked fine yesterday.
iam tring to get on from my Huawei Mate 20 pro and my ipad.
Do you have any tips on how to fix this ?
Look at this thread it may help!
New at this so can’t attach the thread.
I have a AC3200 which I have a HP wireless Printer. For some reason the printer will not connect to the 5ghz band even if i disable the 2.4ghz band on it.
The Printer connects to the 2.4ghz however all of the devices i want to print with are on the 5 ghz band and do not connect to the printer!
Is there a way to bridge the 2 bands!
and i found the problem :)
they were disabled. but the router did that by it self. how can it do that ?
Maybe you inadvertently pressed the WiFi ON/OFF switch.
OE
i did not. it worked then did not. but turned it on again and i will see if it keeps working now
If the problem recurs... I would cycle power, reflash the firmware, reset the firmware, and then reconfigure. I had an 86U 5 GHz band disappear on me once after a firmware upload. I've never seen that before, so I started over and have never seen it since.
OE
