Categorizing messages in Netgear Log Emails
romanstardust
I have an R7800 and was wondering if it would be possible to modify the script that sends out the log messages via email. It currently just dumps them like
[Time synchronized with NTP server] Tuesday, January 05, 2021 22:48:44
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 22:44:08
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 22:43:50
[DoS Attack: ACK Scan] from source: x.x.x.x, port 20025, Tuesday, January 05, 2021 22:28:17
[DoS Attack: ACK Scan] from source: x.x.x.x, port 25565, Tuesday, January 05, 2021 22:11:53
[LAN access from remote] from x.x.x.x:59222 to x.x.x.x:32400, Tuesday, January 05, 2021 22:00:34
[DoS Attack: SYN/ACK Scan] from source: x.x.x.x, port 80, Tuesday, January 05, 2021 21:50:37
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 21:45:54
[DoS Attack: SYN/ACK Scan] from source: x.x.x.x, port 80, Tuesday, January 05, 2021 21:19:10
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 21:01:59
[DoS Attack: ACK Scan] from source: x.x.x.x, port 5223, Tuesday, January 05, 2021 20:56:32
[DoS Attack: SYN/ACK Scan] from source: x.x.x.x, port 443, Tuesday, January 05, 2021 20:55:17
[DoS Attack: SYN/ACK Scan] from source: x.x.x.x, port 55555, Tuesday, January 05, 2021 20:34:58
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 20:30:38
[DoS Attack: SYN/ACK Scan] from source: x.x.x.x, port 443, Tuesday, January 05, 2021 19:30:53
[DHCP IP: x.x.x.x] to MAC address x:x:x:x:x:x, Tuesday, January 05, 2021 19:27:46
I want to make them be split into categories like so
NTP
DHCP IP
DoS Attack
[LAN access from remote] from x.x.x.x:59222 to x.x.x.x:xxxx, Tuesday, January 05, 2021 22:00:34
What would be the way to do this? I assume I need to modify some CGI code or something
kamoj
You can simply modify: /etc/email/email_log for your needs?
NTP
DHCP IP
DoS Attack
kamoj
Now I'm home and can give you an simple example:
If you change this in /etc/email/email_log :
sed -n '1! G;$p;h' $LOG_FILE | sed -n '1,256 p'
To:
tail -n256 "$LOG_FILE" | sed -n '1! G;$p;h' >/tmp/MAIL.lines
awk '{print $1" "$2}' /tmp/MAIL.lines | sort -u | sed '/^ *$/d' | while IFS= read -r line; do
   echo "$line" | tr -d "["
   grep -F "$line" /tmp/MAIL.lines && echo ""
done
then the output will be like:
DHCP IP:
DoS Attack:
LAN access
Time synchronized
I have an R7800 and was wondering if it would be possible to modify the script that sends out the log messages via email. ...
romanstardust
To:
sed -n '1! G;$p;h' $LOG_FILE | sed '1,256 p' >/tmp/MAIL.lines
done
DHCP IP:
DoS Attack:
LAN access
Time synchronized
Wow! Thanks a ton! I'll give it a go
UPDATE: Just tried and the code above works perfect. Thanks again! My logs make sense now
romanstardust
Incase someone wants to have this change done automatically via the Autorun functionality, here are the commands for it
Bash:
sed -i '[email protected] -n .1! G;$p;h. $LOG_FILE | sed -n .1,256 [email protected] -n256 "$LOG_FILE" | sed -n ℞1! G;$p;h℞ >/tmp/MAIL.lines\n℥℥℥awk ℞{print $1" "$2}℞ /tmp/MAIL.lines | sort -u | sed ℞/^ *$/d℞ | while IFS= read -r line; do\n℥℥℥℥echo "$line" | tr -d "["\n℥℥℥℥grep -F "$line" /tmp/MAIL.lines \&\& echo \""\n℥℥℥[email protected]' /etc/email/email_log
sed -i "s/℞/'/g" /etc/email/email_log
sed -i "s/℥/$(printf '\t')/g" /etc/email/email_log
I had to split it into 3 commands for it to be done correctly. The first one will do the bulk of the work. The second command simply replaces ℞ with '. The third one replaces ℥ with TABs as the Netgear version of sed doesnot support the \t command
NOTE: Please modify the Autorun file via a GUI based editor. When trying to do it directly via SSH on the Router itself, both "nano" & "vi" were unable to correctly add/display the lines above.
romanstardust
I made an updated version of this script, which summarizes the log lines, so that it is even easier to read.
The main changes are
- DHCP IP assignment is summarized and shows a max of 5 assignments per IP/MAC combo
- DHCP IP Address being assigned to more than 1 MAC, it will be flagged as [DUPLICATE]
- DoS Attack is summarized by IP & Port
- If DoS Attack from a source IP hits multiple ports, those will be flagged as [MULTIPORT]
- Minor formatting changes
Sample output
DHCP IP
[DHCP IP: xxx.xxx.xxx.xxx] to MAC address - RA:ND:OM:MA:CA:DD - 2 - times
   Friday, January 01, 2021 00:00:00
[DHCP IP: xxx.xxx.xxx.xxx] to MAC address - RA:ND:OM:MA:CA:DD - 5 - times
--- Truncated - Last 5 shown ---
DoS Attack
[DoS Attack:] From source - xxx.xxx.xxx.xxx - to port - 5223 - 4 - occurences
   ACK Scan --- Friday, January 01, 2021 00:00:00
[DoS Attack:] From source - xxx.xxx.xxx.xxx - to port - 443 - 2 - occurences
Initialized, firmware
   [Initialized, firmware version: V1.0.2.89SF] Friday, January 01, 2021 00:00:00
How to use
- Save the attached text file and change the extension to .sh
- Save it somewhere on the router
- Include it in the /etc/email/email_log by using source. Eg: source /path/to/script.sh
- Change this line in /etc/email/email_log to call the function from the script
to
print_modified_log
Autorun Sed commands
If you are using a USB, add these commands to the autorun file located at /mnt/sda1/autorun/scripts/post-mount.sh to automatically make the changes. They will replace the "sed" line and add the "source" command to the Line#2 of the "email_log" file
sed -i 's/sed -n .1! G;$p;h. $LOG_FILE | sed -n .1,256 p./print_modified_log/g' /etc/email/email_log
sed -i '1 a source /mnt/sda1/custom_logs.sh' /etc/email/email_log
EDIT: The second autorun line had an error. Updated
5th December 2021 - Fixed bugs in script. Updated
18th December 2021 - Fixed more bugs with DOS Attack Section in script.
  • print_modified_log.txt
