Jaybo
OK I know just enough to be very dangerous,and this problem is driving me crazy having spent New years eve and day trying to figure out the problem. so bear with me.
old setup:
Wireless BB ISP > Dlink 655 Rev.A2 > Dlink DAP 2553 bridge mode > 2553 Bridge/AP mode > switch > Computers.
Worked fine. no real problems, except bridge signal was weak and ISP told me to go with NanoStation Loco M5's to improve my bridge (about 500') Also said to move my router back to my home behind the M5's so I did that. Bridge signal is better. Now, WISP > M5> M5> 655> switch> computers.
the problems is now I am getting the "Error 324 (net::ERR_EMPTY_RESPONSE): The server closed the connection without sending any data." in Chrome and unable to connect error in IE. I can refresh and it will usually go to the site, although sometimes it does not load with all of the borders and such and hit refresh again and all fine.
Live Messenger is also difficult to connect to as well. It is unable to connect, so I run the troubleshooter and it always comes up with a key ports problem. I run repair and it fixes that error but will still not connect until I repeatedly hit the sign in button and eventually it will connect. Nothing changed except for location of router and the new M5 radios.
I was planning to upgrade the router when I found out it is essentially non supported (old Revision A2) when I was going to put the latest firmware on it. (it has the latest for that revision)
What am I missing? I can't take it anymore!
old setup:
