DDNS status...
Jaded
Anyone else getting timed out/exclamation point status on the rt-ac68u? I had a weird reboot last night that caused a chain reaction of reboots and I cant connect to the DDNS service since.. Not sure if its me or if its not up right now...
Thank you
Jerry
Thank you
Jerry
See your System Log, it will give you more details as to what's happening with the DDNS update process.
..says connected to ns1.asuscomm.com on port 80
then next line says...
ddns update: "error recv()ing reply: Connection reset by peer"
ddns update: Asus update entry:: return:
ddns update: retval= 2, ddns_return_code ()
ddns update: asusddns_update: 2
any idea? Its a pain to reboot due to wireless bridge setup...
Thank you for your time
I bounced wan connection and it is functioning as intended now
Thanks again for your time
