K
krl69
Guest
Just got me a gt-ax11000 and installed the latest merling firmware.
Installed Deluge for torrents. Deluge supports Socks5 but I want to use OpenVPN due to speed. Have set up OpenVPN and it works great, but I want to run everything on VPN but with exceptions. Therefore I use VPN Director and it works on devices on the LAN, but Deluge continues to run outside the VPN even though it is not set as an exception. If I drop VPN Director and choose that everything (Redirect Internet traffic through tunnel = Yes (ALL) under OpenVPN settings) should be run via VPN then Deluge also runs via VPN. I have set up in VPN Director the following way: Local IP = 192.168.50.0 / 24 against OVPN1 which is everything on the LAN and all devices on the LAN run via VPN as it should. So e.g. Local IP = 192.168.50.80 against WAN running outside VPN. But Deluge also runs outside even though directly on the router and one would think that it uses the router's IP and which should be intercepted by the VPN Director, but it does not.
