Did 388 break my AIMesh?
ShawnTRD
Everything was working good on 386's for my AX86 and AX82 Node. Now I updated to 388 on both and the Node keeps going offline. I've tried hard resetting and wired or wireless. Can't figure it out.
What 388 you have flashed?
With so many AiMesh compatible router combinations possible sometimes you have to find what works using trial and error method.
After flashing the 388 over the 386, some ppl had the same problem in the Asus ROG Forum/Board and some reported a Hard Reset worked for some of them, strange.
