Do AC clients benefit from an AX router?
Justinh
I have AC clients (4 simultaneously active at any given time) and 1 Ethernet device connected to an RT-AC68U. Wi-Fi coverage and performance are mostly acceptable in my 1,200 sq. ft home. Would an AX router give me any wireless benefit? Would Wi-Fi be any more responsive or consistent or anything?
Since the AC clients can still use only AC technology, I don't know if just having new router hardware would make much difference. If it does, I'll consider the RT-AX86U Pro.
Coming from RT-AC68U - yes. AX-class routers support AC Wave 2. Your router has 10+ years old BCM4360 radios, first Gen AC Wave 1. Coming from RT-AC86U though with BCM4366E radios AC Wave 2, for example - no. It may outperform some entry-level AX-class routers to AC clients.
RT-AX86U Pro will be night and day difference in speed and responsiveness plus about 20-30% better range on 5GHz band, plus it will deal better with interference from nearby networks, plus it will have much longer firmware support. RT-AC68U is approaching End-of-Life like other AC-class routers.
Generally yes - some efficiency on the radio chipsets, and also the main router SoC.
That being said - the AC clients won't be any faster on a single client basis.
In the same room common 2-stream AC client will keep 866/866 link speeds and there will be no noticeable difference, but when you move behind 1-2 walls the older AC68U drops the links to 325Mbps and much newer AC86U and AX86U keep going with 520-650Mbps. The difference is quite noticeable at lower signal levels. I had all three AC68U, AC86U and AX86U at some point for direct comparison to the same AC clients. AC68U falls fast behind.
Well, it sure can't hurt going to a new router! I have mostly AC clients (and one G WIFI cam). Two AX laptops and one AX phone. Two of my AC clients are 160 MHz capable and get great WIFI transfers. However, I would wait for the AX86U Pro to go on sale again (Black Friday is not that far away).
Keep the AC68U for a backup just-in-case (I still have an AC66U_B1 stored).
Here is what the AC class 'king' of routers fared against a quality, but entry-level (good for ~600Mbps speeds or less) AX class router. And to make this clear; it was 2x RT-AC86Us vs. a single RT-AX68U.
And, more...
Is Wi-Fi 6 Worth It
Wi-Fi 6 Pt 2
All 3 routers U are using are at least 3x3 or 4x4 right. So there is something wrong with with ac68u. And I am trying to understand why the ax can still maintain such high link rate
