Enable/Disable Unbound through UI
xScoutx
I'm running nearly the latest version on an ac86u. Diversion/skynet/unbound etc..
I have tried whitelisting everything I can in Diversion to make my Roku's work with Paramount+.
The only thing that works is disabling Unbound via AMTM.
I would prefer to not bypass the filtering for the Roku's because I think it is filtering some ads, but that is an option.
I guess my questions are:
1. Is there anyway or anything I can write even if hosted in another web server to control Unbound? I use terminus on my phone to ssh in, amtm, and disable, but it's a process.
2. Is there a good way to debug what Unbound is doing from a given IP status? Eg what is etting blocked from the Roku's IP?
3. Can you exempt ip's from unbound filtering?
Thank you!
Sites I have compiled and whitelisted in Diversion from google searching (mostly pihole forums for paramount plus) :
ads.play.cbsi.video
c.aaxads.com
cbsi.com.ssl.sc.omtrdc.net
cbsinteractive.hb.omtrdc.net
kvinit-prod.api.kochava.com
na.amazon.com
partnerad.l.doubleclick.net
pubads.g.doubleclick.net
s0.2mdn.net
saa.cbsi.com
tv.rlcdn.com
z.moatads.com
