Feature request: schedule guest network
man_at_work
Hi Merlin,
First of all thanks for all the firmware, thumbs up. However I have a request below.
Is it possible to have scheduler to allow guest network on RTN-66U?
It's allowing the guest network to be allowed only certain timing, e.g. from 8pm - 12am everyday to limit and control the guest connection time.
Thanks,
PS: sorry, I'm not sure whether this is the correct sub forum for such request.
This should be possible and pretty easy through scripting. Perhaps someone else has already done this and will post you some instructions.
nvram settings for the three guest 2.4 networks start with:
wl0.1
wl0.2
wl0.3
nvram settings for the three guest 5.0 networks start with:
wl1.1
wl1.2
wl1.3
To start a guest network in SSH, the command is:
nvram set wl0.1_bss_enabled=1
To stop it, the command is:
nvram set wl0.1_bss_enabled=0
After changing the nvram settings, you need to restart wireless via command:
service restart_wireless
Now you need to get those start and stop commands in a script that will start and stop them when you want. Note that you can start/stop as many as you want, so you could start all of the 2.4 guest newtorks with the commands:
nvram set wl0.2_bss_enabled=1
nvram set wl0.3_bss_enabled=1
Hi Merlin,
Thanks,
The commands to stop/start both the 2.4 and 5G Guest wireless instance #1 are given here by RMerlin:
http://forums.smallnetbuilder.com/showpost.php?p=66327&postcount=2
and if you follow the User script tutorial on RMerlins Wiki:
https://github.com/RMerl/asuswrt-merlin/wiki
you should be able to modify the cron based example script which schedules the LEDs ON/OFF
https://github.com/RMerl/asuswrt-merlin/wiki/Scheduled-LED-control
to enable/disable the appropriate Guest Wireless according to your desired schedule.
Regards,
Hi guys!
I have one question (because I have no clue about writing a decent script).
So What I need is to create a script that turns off my Guest Network at 8pm and then Turn it on at 23:50 that runs every Monday, Tuesday and Thursday...
So I digged a little bit and found a script in "init-start" that I worked fine for me to make a scheduled reboot...
So I has the idea to add the script to the same "init-start" file.
Is this script correct? Using one gru per line/command is ok?
#!/bin/sh
cru a nvram set wl0.1_bss_enabled=1 "50 23 * * 1,2,4"
cru a nvram commit "50 23 * * 1,2,4"
cru a service restart_wireless "50 23 * * 1,2,4"
cru a nvram set wl0.1_bss_enabled=0 "0 20 * * 1,2,4"
cru a nvram commit "0 20 * * 1,2,4"
cru a service restart_wireless "0 20 * * 1,2,4"
cru a ScheduledReboot "0 7 * * * /sbin/reboot"
Tks a lot guys
Hi guys!
#!/bin/sh
Tks a lot guys
Here's another way. The "&&" means to continue if successful. In other words, if a command were to fail, it would not run the next command.
/jffs/scripts/services-start
cru a GuestsAllowed "50 23 * * 1,2,4 (nvram set wl0.1_bss_enabled=1 && nvram commit && service restart_wireless)"
cru a GuestsDenied "0 20 * * 1,2,4 (nvram set wl0.1_bss_enabled=0 && nvram commit && service restart_wireless)"
Thanks a lot! I'll try it and tomorrow let you know if it's working
This Forum Rocks
Tks! The script worked perfectly...
I'll let my script code that include multiple days and a daily restart
I used the init-start file
#!/bin/sh
cru a GuestsAllowed "59 23 * * 1,2,3,4 (nvram set wl0.1_bss_enabled=1 && nvram commit && service restart_wireless)"
cru a GuestsDenied "30 19 * * 1,2,3 (nvram set wl0.1_bss_enabled=0 && nvram commit && service restart_wireless)"
cru a GuestsDenied "30 20 * * 4 (nvram set wl0.1_bss_enabled=0 && nvram commit && service restart_wireless)"
