Jamster001
Hello All.
I have a 30/5 cable connection using a Motorola SB6121 modem. Attached to the modem is my Asus rt-n66u router. The only hardwired device is a PS3. My laptop, xbox360, iPod and TV access the router wirelessly. Here is my problem... I have a FAT32 formatted Seagate FreeAgent GoFlex Desktop 1.5 TB (model: STAC1500100), which has its own power source, connected to the n66u router. On the HDD are .avi files that we would like to access wirelessly via the xbox 360. I made sure the HDD was mounted in the router config page and also set the permissions to "limitless" to allow anyone with network clearance to access the files.
Problem:
On the wireless laptop, that I manage the router config page from, I can access the HDD and view all the .avi files adequately. BUT when I try to view the files on the xbox 360, the HDD is seen but it states that "No Files Found" on the HDD. Oddly though, if I connect the HDD directly to the xbox, all the files are present and can be accessed.
Here are some solutions I have tried which all halt the same problem:
- Formatted the HDD back to NTFS and transferred .avi files back to reformatted HDD.
- Set permissions on the router config page to Admin, Limited, and Limitless but nothing changed except being able to access the HDD on the wireless laptop.
- Tried using Samba service and FTP service with no luck.
Any suggestions? I am using the latest Asus Firmware. Should I try flashing the router with a 3rd-party firmware? Totally lost!
Problem:
