20942 released for 86U !
http://dlcdnet.asus.com/pub/ASUS/wireless/RT-AC86U/FW_RT_AC86U_300438420942.zip
Firmware version 3.0.0.4.384_20942
- Release Note -
Bug fixed and Improvements:
- Improved system stability.
- Improved AiMesh performance.
- Fixed specific models cannot show AiMesh problem.
- Fixed XSS vulnerability. Thanks to Yonghui Han of Fortinet's FortiGuard Labs.
- Fixed CVE-2018-8877, CVE-2018-8878, CVE-2018-8879
- Fixed plain text password vulnerability in lighttpd.
- Modified Quick Internet Setup wizard process.
- Main SSID and guest network can hide independently.
- Fixed OpenVPN client authentication issues.
- Fixed DDNS register bugs.
- Administrator can asisgn specific WAN interface to register DDNS in dual wan load balance mode.
- Fixed OpenVPN client DNS related issues.
@arthurlien: I have still the issue that after apply channel settings are NOT CHANGED at all.
Have to reboot or disable/enable one Wifi 2G or 5G to have it set according to what is shown.
When will this be solved for RT-AC86U at least issue in my china-version with changeable region setting.
Furthermore: Using Aimesh with ethernet backhaul running in AP mode and node set to AUTO but only uses WiFi-connection, must be set to ethernet to run backhaul via wire.
If there exists a LAN-connection it must be used prefered in AUTO-mode!
AiMesh with 68U as node on 20942 working, did a factory reset and nothing else, just power on node and wait to be found on 86U for connecting.
Guest-SSID still not supported on nodes but can be hidden on parent-86U now with this release ...
USB-ports on node not supported too!
