[GT-AX11000] Beta firmware & List of issues
doc octopus
AiMesh works poorly by setting the GT-AX11000 as the main node. How long does it take to provide a working firmware?
I had a really weird issue with the beta firmware. I could not obtain any IPv6 from the router to My Xbox or laptops via LAN lines. WiFi the clients would obtain IPv6 no problem. It was very weird. I went back to the non beta firmware and everything is fine. I have Comcast as internet as provider. Inside the router i have IPv6 set to native.
How can I check that?
Hi, I follow this drama daily and just got out of a major issue..... no I did not go buy a different router!
Here is my set up;
GT-AX1000 main AiMesh router running 9.0.0.4.384_5781-g59be799
RT-AX88U hardwired node running 9.0.0.4.384_5787-g0fcfebf
RT-AC86U x2 hardwired node running 3.0.0.4.384_45149-g467037b
GT-AC5300 wireless node running 3.0.0.4.384_45149-g467037b
I have around 71 connected clients wired/wireless
Coverage is great, speed is great and this last beta has been very good for me even though I see others have had issue.
This was all good up until last night, the main router would not stay connect for more than 15 mins to the internet (Comcast), I would reboot. After a few hours I thought I would reinstall a good working back up setting file to see, nope same old. I let it go over night to see if it would sort itself out but again nope. This morning I reinstalled the 9.0.0.4.384_5781-g59be799 file and all is back to normal.
How odd but please Asus please keep pushing out updates to fix the issues we seem to be having.
