Abouna
OK, I'm hoping someone here has experience with setting up a medium power wifi broadcast. I'm not looking for anything like a whole warehouse or anything but we live on a 1 acre lot with several out building, most of which need wifi.
Current:
-NETGEAR N600 Wireless-N Dual Band Router WNDR3400
-WAP54G
-Amped Wireless High Power Wireless-300N Smart Access Point
-Several linksys switches
All spaced out over several buildings.
What I'd like:
- A simple high power broadcast, hopefully that eliminates all the switches and wireless access points. Maybe also eliminate handoffs.
Is this possible? The reason I assume it's doable is because I can pick up the wifi from the school across the street (about 100 yards away). It's weak but it reaches all parts of our property.
I'm simply tired of having to manage this spaghetti network. Often when any one of the components needs a reset for whatever reason, I typically have to reset everything before the whole works is up and running again. It took me 3+ hours to track down the offending switch today and it was merely a reset to get it all going again.
Help!
Current:
-WAP54G
What I'd like:
Help!
