How can I use user script in AI Mesh nodes?
osk666
Hello, I have a question about script.
I am using 3 AC-68U routers, they are runing in 384.13, one is router, the others are nodes.
It seems that if I enable the ai-mesh node mode, the device will reset its nvram which means I cannot enable the jffs scripts.
My goal is to use scripts to auto reboot if the nodes cannot get the internet connection, because it did happen to lost connection sometimes. And if you see the interface of the router, you cannot find the nodes.
How can I use the scripts in nodes?
Thank you very much.
If the router is set to have jffs enabled. The node also gets jffs enabled automatically. I have my node running amtm scheduled reboot.
