Donaufisch
Hello,
I have an 4G-AC55U ASUS Router. My Provider cuts the LTE Connection once a day. After that cut, the router indicates still "online" but is offline and doesnt goes online again.
Therefore I need to reconnect the connection manually or just restart the router.
I found a Skript to restart the router once a day or every some hours.
"/usr/sbin/cru a ScheduledReboot "0 4 * * * reboot"....
That doesnt work for my problem. In worst case, the router restarts and some minutes after, my provider cuts the connection. The router would then be offline for nearly 24hours.
I need a script to check weather there is a Internet Connection or not. If not, then restart.
That Skript should check every 10 mintes or any other short Intervall. Is that possible?
There is no Merlin Firmware for that router. How can I activate/open SSH Support? I can logon with TELNET
Can anyone help me ?
greetings Roland
greetings Roland
