zaphod1966
I need some advise about wi fi routers with internal antennas under my circumstances. I live in a fairly new home that was wired with CAT5 cable all routed to a metal cabinet in the garage. I am currently running a wired 4 port router. I want to change this router to a new wifi router with 4xLAN ports (fairly std)
Obviously the best place to put to the router is in the metal cabinet. Obviously this may compromise the signal so I am thinking maybe a router with removable external antenna which are then relocated to the outside of the cabinet.
Do I need to worry ? - should I just buy a router with internal antenna ?
