Internet Disconnected when VPN turns on - 386.1 Beta 2
wizin
I was trying to configure my Torguard VPN which eventually worked by uploading .ovpn via their site
But as soon as it satisficed that connection, I got internet disconnected
I had to reboot,. I touch the VPN side and it goes internet disconnected
I tried using default DNS and tried google one too but same thing
Attached log
  • log.pdf
L&LD
Part of the Furniture
As a workaround, did you try turning off the WAN and then turning it on again, via the GUI?
kamoj
Your log indicates you run 2 clients simultaneously.
I suggest you try with only one (1) OpenVPN Client.
At least it makes the log easier to read.
Billy Chaney
Attached log
Yeah, I'm having the same problem. For the time being just turn on one and reboot. That will take care of your problem for now.
wizin
Thanks, yea its 2 VPN's so works with 1 - is this due to Beta? coz it worked fine in 386.19
trunkroll
I have the same problem when trying to run 2(or more) VPNs simultaneous on my ax86u on the Beta2. 1 VPN will work fine by itself, but trying to run a 2nd will stop WAN completely and need a reset.
octopus
Try to toggel wan off/on that should com back again.
mbze430
I have two TorGuard clients running on my AX88U 386.1 Beta2 it works fine.... but every time you make some changes to it it will drop WAN. But restarting the interface will bring it back up
