sentinelvdx
I'm trying to troubleshoot my connection which is randomly failling, causing a full disconnect from the internet.
I was reading the syslog to find out if I do need to reset my router (not doing it since 2 previous firmwares) or if it's an ISP issue
Any help understanding syslog is welcome:
Sep 17 21:38:52 pppd[1837]: Connected to XX:XX:XX:XX via interface eth0
Sep 17 21:38:55 wan-event[25649]: Started wicens with pid 25651
Sep 17 21:38:56 ovpn-server1[13309]: Connection Attempt event_wait : Interrupted system call (fd=-1,code=4)
Sep 17 21:38:56 ovpn-server1[13309]: PLUGIN AUTH-PAM: Error signaling background process to exit: Connection refused (errno=111)
Sep 17 21:38:57 inadyn[26125]: alias address=<186.132.456.789>
Sep 17 21:38:57 inadyn[26125]: request<GET /ddns/update.jsp?hostname=xxxxxxxx.asuscomm.com&myip=186.132.456.789&model=RT-AX86U&fw_ver=3.0.0.4.388.4_0 HTTP/1.0^M Authorization: Basic RjAyRjc0OTFCRTYwOjk2OERDQ0Y2OTZCOEY4NzYzRjQ3QjVFNTFGREVCMDU4^M Host: ns1.asuscomm.com^M User-Agent: inadyn/2.10.0 https://github.com/troglobit/inadyn/issues^M ^M >
Sep 17 21:38:57 ovpn-server1[26290]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sep 17 21:39:05 Diversion: restarted Dnsmasq to apply settings
