Scott Kaforey
I just migrated from an AC68 to an AC88. Previously I had home assistant running without any issues at all. I had 2 cell phones on my network that were monitored using nmap from the home assistant to tell if my wife and I were home. Both phones are setup with static DHCP.
After switching over to the AC88, I noticed I was getting a bunch of false positives, meaning that home assistant wasn't able to locate me on the network (I'm guessing nmap uses ping?). This happens throughout the day.
In addition, a few devices I have setup on home assistant are unable to to be communicated with. My wifi smart switches can't connect for whatever reason when the home assistant is restarted. They also are setup with static DHCP. I connected directly with the home assistant and ping'd the smart devices and they respond instantly.
Restarting the router seems to fix things temporarily.
I did start fresh on the AC88 (no copying of config files or anything). All of my wifi information is the same (since all the devices immediately connect to whatever router is on). I went through seemingly every single page of configurations to make sure all the settings match. The only difference is that my old router was on 384.7 and my new one is on 384.13.
I know this isn't directly related to Merlin, but my thought is that there's some sort of setting somewhere that might be blocking, rate limiting, throttling, caching, or SOMETHING that I can't think of. While I was having problems, I unplugged the new AC88, plugged in the old AC68 and everything immediately started working again.
I'm really at a loss here and hoping someone can help me out.
