Merlin 3004_388.10_alpha1 (now 3004_388.10_alpha2 for most devices)
5Ghz kept restarting every 5 minutes so all my clients kept losing their connections. Reverted back to 9_2.
have you tried installing ScMerlin and then using the restart wifi option in there?
There's something else going on then, since there were no WiFi changes since 388.9_2.
The upgrade corrupted the attached USB Drive somehow, causing Addons to not work properly. Working on restoring it now.
Having white text in the default or light theme makes the text unreadable.
It's amazing how many times I've come across difficult to read text in commercial software/apps with my assumption being the developer uses dark mode and never tested their software with light mode. I blame SNB forums for teaching me enough "coding" knowledge to recognize this kind of thing. A blessing and a curse.
Some time ago a company arrived at my business to do software presentation. It was very short because of dark mode only interface.
I find this subject very funny as I use dark mode exclusively and don’t like having to switch when it’s necessary.
I don’t think I’m missing out on any extra vitamin D by making this choice.
I use light mode on all screens except in cars for obvious reasons. I used to read books a lot and still do. I have yet to find black paper book with white print. Monitors have reading mode brightness these days. Some make it look pretty natural. I also have e-reader and its screen is obviously light with black print. This is my choice. Developers not making or testing their software with light interface don't get any money from me.
Paper is fine and I prefer it that natural way, the paper doesn’t glow and you can adjust the ambient light better.
On a screen, even with the brightness turned way down, the glow is bothersome. Hard to make it natural.
Agree that both sides should have a choice and assuming that the split is 50/50, it’s an oversight to loose half your audience.
A few days with the alpha and everything is rock solid.
Updated my AX86U without issues as well.
Updated my node RT-AX3000 (aka 58U) last week and has been solid.
Main router, RT-AX86U Pro has VLAN IoT with 20 devices and has also been solid since 102.5 release.
I have an identical setup on my local system. Also updated my AX3000 last week and all seems generally ok although I have a couple of Sensibo Sky units (separate thread) close by the AX3000 that fall off the Wi-Fi unless I bind them to the main Router. Probably unrelated.
