Sorry if this is a simple question I ought to know the answer to.
I have an AX86U and an AC68U as an Aimesh node. I see the firmware for AX variants is now up to 388.1 but for AC variants it is staying at 386.7.2. I think I remember seeing that you should keep nodes on the same firmware version as the primary router.
Is it OK to update the firmware on my AX86U to 388.1 but leave the firmware on the AC68U as 386.7.2? Do I understand that the AC routers will not be getting 388.1?
TIA
TIA
