Solved Need som help to choose tun inteface
octopus
I'm strugeling with this and can't get it working. Is there som smart guy's have any suggestion?
I'm trying to choose different "tun" inteface to send my mail on. eg. route-up on "tun11" and route-pre-down on "tun13" (have both running)
But it seems only one tun interface is used (tun11).
This is only som code <snippets>
Thanks !!!
vpn=$1 (tun [1-5])
if echo "${script_type}" = "route-up" && echo "$vpn" | grep -oE "[3]"; then INFACE="tun13"; fi
if echo "${script_type}" = "route-pre-down" && echo "$vpn" | grep -oE "[3]"; then INFACE="tun11"; fi
send(){
case $1 in
mail)
/usr/sbin/curl -s -S -4 --interface "$INFACE" \
--url smtps://$SMTP:$PORT \
--ssl-reqd \
--mail-auth $USERNAME \
--user "$USERNAME:$PASSWORD" \
--mail-from $FROM_ADDRESS \
--mail-rcpt $TO_1 \
--upload-file /tmp/rc-mail.txt
RC=$?
I know, maby in wrong thread.......
eibgrad
[ "${script_type}" == 'route-up'       ] && [ "${vpn:4:1}" == '3' ] && INFACE='tun13'
[ "${script_type}" == 'route-pre-down' ] && [ "${vpn:4:1}" == '3' ] && INFACE='tun11'
octopus
[ "${script_type}" == "route-up"       ] && [ "${vpn:4:1}" == '3' ] && INFACE='tun13'
[ "${script_type}" == "route-pre-down" ] && [ "${vpn:4:1}" == '3' ] && INFACE='tun11'
Thanks! I gon test later one, have to take some puse from this.
dave14305
Part of the Furniture
I don’t think it works the way you expect.
octopus
Thanks!!
This working just fine, I only needed to change "{$vpn}" just only one digit coming.
octopus
I have modified a little, working just fine now.
case "${vpn}" in
1)
[ "${script_type}" = "route-up" ] && INFACE='tun11'
[ "${script_type}" = "route-pre-down" ] && INFACE='tun13';;
2)
[ "${script_type}" = "route-up" ] && INFACE='tun12'
[ "${script_type}" = "route-pre-down" ] && INFACE='tun12';;
3)
[ "${script_type}" = "route-up" ] && INFACE='tun13'
[ "${script_type}" = "route-pre-down" ] && INFACE='tun11';;
4)
[ "${script_type}" = "route-up" ] && INFACE='tun14'
[ "${script_type}" = "route-pre-down" ] && INFACE='tun14';;
5)
[ "${script_type}" = "route-up" ] && INFACE='tun15'
[ "${script_type}" = "route-pre-down" ] && INFACE='tun15';;
esac
