I was running an RT-n66u with Merlin fw for years and could connect multiple simultaneous devices/users.
After swapping to an RT-AX86U, immediately flashed to Merlin fw. The new router can only handle one connected device at a time!
(Right now I'm on version 386.5_2, but when I started 3 versions back it was the same)
I have tried setup one TAP and one TUN server and if I connect a PC to the TAP server and then connect an Android to the TUN, the TAP stops working.
I have tried with different VPN user accounts, but it does not help.
Used to have one PC off-site connected and connect on my phone when needed, but now the PC goes down if I connect with the phone, or the phone doesn't work when PC is connected.
Anyone has some ideas?
cheers
cheers
