OpenDNS update IP address at router level instead of client
Daveo
I use OpenDNS and know they do a windows client to update the IP address registered with them if it changes.
Any way to do this at the router level, as I use various devices and can't install the OpenDNS client on them all.
Zastoff
Dnscrypt installer has a function for Opendns(cisco) ip update
edit:
The installer detects if Opendns (cisco) servers is selected during setup and askes if you want to setup the ip update
Daveo
Cool, thank you.
I will have a look into it.
Daveo
edit:
How do I setup DNScrypt to work with OpenDNS, as when I tried to do this, I couldn't find anywhere during install where it allows me to select OpenDNS.
Zastoff
The OpenDNS servers is called Cisco in the list of servers
Daveo
Could you run through what I need to select during each stage of the installer as it asks a lot of questions, some of which I'm unsure of.
Zastoff
Can maybe take a look at this post it`s a guide for nextdns but you just select cisco server instead and you will get a question at the end to setup the ip update
Daveo
So is this where I put OpenDNS server info...
Info: Choose how your DNS servers are selected:
1) Automatically
2) Manually
3) Static
=> Select your mode, [1-3]: 2
=> Please choose DNS server, [1-190]: find the nextdns server in list that is displayed and enter that number
=> Please choose next DNS server or press n to stop, [1-190/n]: n
Info: Set the DNS server(s) for initializing dnscrypt-proxy
Info: and router services (e.g. ntp) at boot
=> Default is 9.9.9.9: 1.1.1.1 << Replace with OpenDNS
=> 2nd Default is 8.8.8.8: 9.9.9.9 << Replace with OpenDNS
Zastoff
1) Automatically
2) Manually
3) Static
No
You do not enter the server manually, You select Cisco server from the list that you get from
1) Automatically
2) Manually
3) Static
and it should display a lot of servers
enter the number for Cisco (it`s Opendns server)
Daveo
OK thank you
Daveo
Think I've got this working now, as it did ask for my OpenDNS account info.
