Voxel Orbi Rbk53 v2 Bufferbloat problem ( Stock or Voxel)
RAZIAR
Hi everyone ,
Is there any way to reduce the bufferbloat on an orbi rbr 50 v2 ( without usb) , maybe Qos , Sqm , or any bandwidth control ? I'm having D or F on dslreports every time , any devices connected to wifi makes the ping spikes to hundreds of MS .
I've found a junky solution by using my orbi like an AP , and leaving my old router handling it with bandwidth control ( by reducing the speed and priority of others devices ) . This solution works but is not ideal , cause i have a dsl modem connected to a router then to orbi . I've noticed that my internet speed ( and ping ) is better when i use the orbi directly connected to the modem as a router , but then the bufferbloat is out of control , and it's impossible to game whatsoever .
So if anyone has to solution for controlling or reducing buffer bloat on Voxel firmware , i would be very grateful , Thanks
