Hello,
I'm having an issue I'm hoping someone might be able to help with. I'm currently running Merlin 380.68 on a RT-AC5300 and every 24 hours my PPPoE connection is dropping then renegotiating. I've tried working with my ISP and they couldn't find anything on their end, their logs show that I am disconnecting as if I had powered off my router. I'm fairly sure it's something in the router as whenever I upgrade my firmware the timing of when the connection drops changes to be 24 hours based on when the firmware update completed. I've tried moving to a different VDSL card at my provider and changed out my modem and problem still persists. Below I'll attach what I see in the logs every 24 hours.
I've tried resetting to factory default and the issue still happens even if I make no changes to the router config other than to put in my PPPoE information.
Anyone have any ideas on this?
Thanks,
WFO
Sep 3 12:26:53 pppd[792]: No response to 10 echo-requests
Sep 3 12:26:53 pppd[792]: Serial link appears to be disconnected.
Sep 3 12:26:53 pppd[792]: Connect time 1439.8 minutes.
Sep 3 12:26:53 pppd[792]: Sent 760662684 bytes, received 3640923967 bytes.
Sep 3 12:26:53 miniupnpd[19596]: Failed to get IP for interface ppp0
Sep 3 12:26:53 miniupnpd[19596]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Sep 3 12:26:53 WAN_Connection: Fail to connect with some issues.
Sep 3 12:26:53 DualWAN: skip single wan wan_led_control - WANRED off
Sep 3 12:26:53 stop_nat_rules: apply the redirect_rules!
Sep 3 12:26:59 pppd[792]: Connection terminated.
Sep 3 12:26:59 pppd[792]: Sent PADT
Sep 3 12:26:59 pppd[792]: Modem hangup
Sep 3 12:27:09 pppd[792]: PPP session is 58217 (0xe369)
Sep 3 12:27:09 pppd[792]: Connected to [xx:xx:xx:xx:xx:xx] via interface eth0
Sep 3 12:27:09 pppd[792]: Using interface ppp0
Sep 3 12:27:09 pppd[792]: Connect: ppp0 <--> eth0
Sep 3 12:27:09 pppd[792]: PAP authentication succeeded
Sep 3 12:27:09 pppd[792]: peer from calling number [xx:xx:xx:xx:xx:xx] authorized
ETA: Router model
Thanks,
WFO
ETA: Router model
