First you must find out exactly which Netgear stock firmware it was last working with.
"v62 or something" is not enough.
Post that information here, please.
Then you could try with Netgears site:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
PS
Netgear's release notes:
R7800-V1.0.2.58:
[New Feature] Increases the maximum traffic meter limit to 4095 TB.
[New Feature] Adds ability to sync NTP setting and configure local timezone so users can avoid auto firmware update in the middle of the day.
[New Feature] Removes support for channels 132, 136, and 140 in 5G_HT80 mode to meet regularity.
[Bug Fix] Fixes an issue where the name of the attached device disappears if the firmware is updated to V1.0.2.52.
[Bug Fix] Fixes security issues.
[Bug Fix] Fixes minor bugs.
R7800-V1.0.2.60:
R7800-V1.0.2.62:
[New Feature] Modifies the router web interface to support DDNS GDPR v3.
[New Feature] Includes a new NETGEAR banner logo.
[New Feature] Removes Step 1 from the ReadySHARE Vault page in the router web interface, which asked to install the genie app.
[New Feature] The http request will not be redirected when the router detects a WAN/LAN IP conflict in the blank state.
[New Feature] Updates dnsmasq to V2.78.
[New Feature] Includes a login password enhancement in the router web interface to support a more secure password.
[Bug Fix] Improve the stability of the wireless 5G interface.
[Bug Fix] Fixes the issue where the speed test in the QoS page always displays a zero number.
[Bug Fix] Fixes the issue where if the MTU value is set to 1492 in PPPoE mode, some IPv6 web site can t be accessed.
[Bug Fix] Fixes some minor bugs.
R7800-V1.0.2.68:
[New Features] Supports FCC channels 136, 140, and 144.
[Bug Fixes] Fixes minor bugs.
