In short, my RC-AC66R is only giving me on average 80 Mbps of my 150 Mbps connection when wired. My connection only averages 40 Mbps and often slows to below 5 Mbps.
Longer Description:
I have had this router for about three months and it has worked very well. I don't remember testing the speeds at that point because everything was working well. A few weeks ago I got a notice from Comcast that my speed has been increased from 100 to 150 Mbps. After restarting my modem I started testing speeds and noticed some issues:
1. When wired I was only getting about 80 Mbps. I connected directly to my modem and got over 150 Mbps consistently. These speeds are consistent. Testing this morning I get those same speeds.
2. My Wifi speed is even lower. Maybe this is normal, but the highest speed I can get directly next to my router via Wifi is 60 Mbps. It averages about 40 Mbps upstairs. This is when things are "normal."
3. At times my Wifi speed drops to be below 5 Mbps. I haven't thoroughly tested times of day and such, but have noticed this several times in the evening while trying to play our upstairs Xbox. Lag and being dropped from games led to testing in those moments to find very slow speeds even with my laptop right next to the router. Sometimes it would be better on either 2.4 GHz or 5 GHz.
Here is what I have done to address this issue with no help so far:
Longer Description:
- Checked that I have latest firmware.
- Relocated the router
- Turned off QOS
- Set Control Channel to 40 and Channel bandwidth to 80 MHz on on 5GHz
- Restarted modem and router repeatedly
