I have read many of the reviews and the articles on how to buy a router. I currently have a 10 Mbps cable modem.
I currently have a mixed pc (xp/sp3)/mac (10.3.9) setup, both g. Soon I will have a mixed pc/mac g/n setup with 2 macs g/n (old plus new mac) and a new pc/n (xp/sp3). (avoiding vista for now). By next year I'll only have n, but by then there will be newer routers too.
I intend to route the 2 closest machines via cable, and only use wireless for the farthest mac.
A more pricey simultaneous dual band router seems enticing because I can segregate the g and n, however, I then have to pay bucks for vendor matched usb or cardbus adapters & I don't even know if these work with macs.
Same goes for Mimo / rangebooster g routers - buy vendor adapted adaptors to go along with their proprietary systems (work for macs?).
So - have I talked myself back to a plain g router? I am not transferring video or other large files, however I might want to use a NAS for backup so I don't have to attach an external hard disk locally to each machine.
I ask for
good security
NAT
an SPI that is updated routinely for new exploits
MAC filtering
do i need a DHCP server?
WPA2 with decent encryption
ability to change SSID / disable broadcast of SSID
Have I missed something important needed for security?
I don't think I need QOS (when we start to use Skype, we'll just dedicate the machine to that for the length of the call).
I really need help here. Will vendors keep updating older routers? What I don't want to see happen is the LAN speed falling below the 10 Mbps of the Internet connection.
I have read more positive posts and reviews of Linksys and D-link, and Linksys seems to have a solid forum based community that I can turn to when inevitably setup does not work, etc. There is always this community as well. I have read about many, many routers, but am still unsure which to buy.
I really appreciate any help available. If I have not laid out my situation clearly enough, please ask me more questions.
Deb
I ask for
good security
NAT
MAC filtering
Deb
