Freek
Hello,
I'm replacing our company's WiFi routers for the 3th time now in 2 years. Currently, we have 4 Draytek AP800 WiFi AccessPoints, as we had good experiences with Draytek in the past. However, these access-points have caused our nothing but trouble; They reboot randomly every 48 hours. Apparently, after a lot of troubleshooting and research, according to Draytek, these access-points do not support wireless roaming and if used for wireless roaming, will cause interference and will reboot randomly. Great...
Therefore, we are looking to replace these 4 routers/access points with proper ones that do support wireless roaming; We have 2 SSIDs (private and guest), shared among those 4 routers/access points using the same encryption but using different channels (1, 6 and 11).
Our demands are pretty standard; We do not use fancy features as VPN, we just want a functional WiFi network with a decent range and wireless roaming (i.e. 2 SSIDs with multiple access points). If possible, the guest network should have it's own DHCP range. Note that for SSID1 I should be able to disable the DHCP server, as the routers/access points will be connected to our exisiting wired network with it's own DHCP server.
Our WiFi is mainly being used to surf the internet, send mails and printjobs to our printer. Our internet speeds are quite low at 20Mbit/20Mbit
Our company has about 10 wireless clients, although spread about a large area, hence the multiple accesspoints/wireless clients.
Our budget is around 150$ per access point/router.
I'm looking forward to your recommendations. Personally I've found the ASUS RT-N66U Dark Knight to be suitable, although I was unable to find if it support wireless roaming.
Thanks in advance!
Kind regards.
Thanks in advance!
Kind regards.
