dev_null
New AX86U, getting scripts set up. Trying to install cake-qos script from here: https://github.com/ttgapers/cakeqos-merlin
I'm getting the below (fatal) error. But when I check the sbin folder, sure enough 'tc' is present (and the script calls tc a number of times well before the 'error in 759'). FWIW in note++, line 759 is 'esac'.
I was going to post over on the github page, but there doesn't seem to be much traffic over there...
Thanks for any insights.
CakeQOS-Merlin: Starting - ( 110Mbit | 5Mbit | besteffort | | )
Broadcom Packet Flow Cache HW acceleration <DISABLED>
CPU Speed (*) ==> Disable
Changing power settings. Forcing cpu to max frequency.
Set cpuspeed to on(pwr config --cpuspeed on) to make it adaptive again
Broadcom Packet Flow Cache learning via BLOG disabled.
Broadcom Packet Flow Cache flushing the flows
./cake-qos: line 759: /opt/sbin/tc: not found
RTNETLINK answers: File exists
<<snip>>
757 printf '%-32s | %-55s\n' "cake-qos uninstall" "uninstall and remove all traces of $SCRIPT_NAME"
758 ;;
759 esac
760 Display_Line
761 if [ -n "$reloadmenu" ]; then echo; printf "[*] Press Enter To Continue..."; read -r "reloadmenu"; exec "$0"; fi
<<snip>>
