RT-AC3100 Adaptive QoS Broken?
asusrunshot
Can someone with ASUS RT-AC3100 running official firmware confirm that upload queue for Adaptive QoS is broken in stock firmware from 2 versions ago? I already tested the latest version and it seems to be broken.
Can you run this code?
tc qdisc show | grep direct_p
Only need to see the output on upload:
qdisc htb 1: dev eth0 root refcnt 2 r2q 10 default 0 direct_packets_stat 794
I am looking for other hardware units that have the problem of direct_packets_stat > 100. Trying to find out if ASUS QoS is broken in upload.
It works correctly on download with direct_packets_stat not increasing at all.
