sirwifi
Is it possible to assign the WAN port to the LAN switch either with the stock or the Merlin firmware? I read somewhere that this may work when in Access Point mode but I couldn't find a definite answer. I just need a "dumb" 5-port switch + AP, behind another wired router/gateway.
So, is anyone using this RT-AC66U model in Access Point mode and is able to use the WAN port as a 5th LAN port? Thank you.
