RT AC86U 2900 firmware update.
Grommit
Hi. I'm new to a lot of this stuff. I've just bought an RT AC86U 2900, running 3.0.0.4.386_41634 firmware, but want to use vpn split tunneling (some devices using expressvpn, some not). If I update to to Merlin, will split tunneling be available to me? And I won't lose any router functionality?
Thanks in adavnce. Sorry if I'm asking questions that have already been answered. I'm a bit worried most posts refer to RT AC86U, not RT AC86U 2900...
ColinTaylor
Part of the Furniture
The "RT-AC86U 2900" is the same as "RT-AC86U". Some sellers just like adding lots of different words to the title.
Yes Merlin's firmware does do split tunnelling with its Policy Based Routing.
bbunge
Calling your router the AC86U is just fine.
Flashing the Merlin firmware will give you many more functions and a newer version of OpenVPN. Not sure about split tunnels.
If you decide to stay with Asus firmware you should upgrade to the 9.0.0.4.386.41994 Beta Version as it fixes several security issues.
Grommit
Hi Bbunge. Thanks for that, but I think I'll give Merlin a go. I really want to seperate my traffic between vpn and non vpn.
