piotrpiano
Hi there,
As I didn't find to much information searching the web as to what kind of speeds I should expect from my rt-n66u running USB samba share, and some reports I managed to find were quite diverse and often lacking important information about connection method, used filesystem etc., I thought it might be a good idea to start one thread here and deal with this subject once and for all...
My test conditions:
-TomatoUSB Shibby 095 AIO firmware on Asus RT-N66U
-Tested on wired and 5Ghz connection (40 Mhz, Auto channel, WPA2-AES, N-only )
-Intel WiFi Link 5100 AGN and Realtek PCIe FE Family controller (100 Mbits)
WD 250GB 5200 rpm USB2 hd (usb powered) with ntfs, fat32, ext2 and ext3 partitions
-Wifi performace tested from a distance of 1 meter, clear sight
-Tested with Lan Speed Test (free version) and direct copying of a file measured with Networx Speed Meter
-All tests were repeted 3 times and the result were averaged
-All results given in MB - MegaBytes per sec.
Now to the numbers:
Wifi 5Ghz connection, 118 MB file:
NTFS : write - 1.8 MB read - 4.7 MB
FAT32: write - 3.5 MB read - 6.5 MB
EXT2: write - 3.6 MB read - 6.5 MB
EXT3: write - 3.5 MB read - 6.5 MB
Wifi 5Ghz connection, 20 MB file:
NTFS: write - 1.9 MB read - 6.0 MB
FAT32: write - 3.2 MB read - 6.2 MB
EXT2: write - 3.6 MB read - 6.1 MB
EXT3: write - 3.5 MB read - 6.1 MB
Wired connection, 118 MB file:
NTFS: write - 2.1 MB read - 5.0 MB
FAT32: write - 5.2 MB read - 7.7 MB
EXT2: write - 6.2 MB read - 7.4 MB
EXT3: write - 5.7 MB read - 7.7 MB
Wired connection, 20 MB file:
NTFS: write - 2.4 MB read - 7.7 MB
EXT2: write - 6.3 MB read - 7.6 MB
EXT3: write - 5.9 MB read - 7.6 MB
I actually started this test on an externally powered WD 320GB 7200rpm usb2 hdd but as it is slowly dying, I was just getting stuck on bad sectors. I was however able to get a reliable result on ext3 partition which was 4.7 MB - write and 7.3 - read with 118 MB file over 5 Ghz connection.
I am going to try this test with Asus firmware once I have a moment to flash my router with it.
Please share your results and, when you will, please be specific as to which firmware version you are running, your hdd type (ext.powered/usb powered) and speed, HDD filesystem, connection type.
Cheers,
Piotr
[EDIT]
FWIW, I tested samba share with latest Asus/Merlin build 3.0.0.3.157.12 Beta.
Wifi 5 Ghz, 118 MB file:
NTFS: write - 4.1 MB read - 6.6 MB
FAT32: write - 4.1 MB read - 6.6 MB
EXT3: write - 3.9 MB read - 6.9 MB
EXT2: write - 4.0 MB read - 6.9 MB
Wifi 5Ghz, 20 MB file:
NTFS: write - 4.2 MB read - 6.7 MB
FAT32: write - 4.1 MB read - 6.5 MB
EXT3: write - 3.8 MB read - 6.7 MB
EXT2: write - 4.0 MB read - 6.8 MB
Wired, 118 MB file:
NTFS: write - 6.0 MB read - 6.0 MB
FAT32: write - 5.6 MB read - 6.0 MB
EXT3: write - 5.3 MB read - 6.7 MB
EXT2: write - 5.9 MB read - 6.3 MB
Weired, 20 MB file:
NTFS: write - 5.7 MB read - 6.0 MB
FAT32: write - 5.3 MB read - 5.7 MB
EXT3: write - 5.4 MB read - 6.4 MB
EXT2: write - 5.7 MB read - 6.5 MB
Two things to note:
- on OFW the performance of ntfs is on par with other filesystems - no reason to choose ext over it (performance-wise)
- for some strange reason the performance over wired connection (reading) seems to be worse than over wifi 5Ghz... (?)
My test conditions:
Now to the numbers:
Cheers,
Piotr
[EDIT]
Wired, 118 MB file:
Weired, 20 MB file:
Two things to note:
