I'm leaning toward either the RV320 or EdgeRouter Lite for my home network to replace a Zyxel USG50. Probably leaning moreso toward the ERL since the simultaneous up\down rates will be closer to Gigabit if it ever becomes available in my area. Other than that, the two routers appear to have all features that I'm looking for except that I've read a few rumors that I'm hoping to clear up.
For all intents and purposes, my WAN IP is not static. I use No-Ip as my dynamic service. I see both routers support this DDNS provider and handle updates. Perfect. However, I've read things about a limitation on the RV320 and I'm not sure if I'm reading current information. Essentially, when setting up a Ipsec Client to Gateway group tunnel, it's my understanding that you cannot state that the dynamic WANIP internal to the gateway is the IP to be used. Are there limitations surrounding this? And although the settings appear to allow L2TP to passthrough firewall-wise, I did not see a setting any mention of L2TP over the Ipsec as a setting in the Ipsec configuration. Is it just assumed that L2TP over Ipsec or straight Ipsec are both enabled?
Just wanted to see if anybody could dispell that tidbit or if it would be a risk that would probably confirm that my gamble would be on the ERL.
